Looping through a component's children
Because Mattercraft is built on Three.js, every node in the scene is a THREE.Object3D. You can iterate over a node’s direct children using the children array, or walk the entire subtree using traverse():
// Direct children only
for (const child of this.instance.children) {
// Do something with each direct child
// All descendants (including nested children)
this.instance.traverse((child) => {
// Do something with each node in the subtree
traverse() includes the node itself as the first call. If you only want descendants, you can skip it by checking child !== this.instance.
Example usage
The following example hides all direct children of the node the behavior is attached to when the experience starts:
import { Behavior, zBehavior, zOnStart } from '@zcomponent/core';
import Scene from './Scene.zcomp';
@zBehavior({ icon: 'account_tree' })
export class HideChildrenBehavior extends Behavior<Scene> {
@zOnStart()
private _init() {
child.visible = false;
For more on working with Three.js objects in Mattercraft, see the API References.
