Fetching JSON data
Data from an external API can be fetched using the browser’s fetch() API. Making the @zOnStart method async allows you to use await to handle the response cleanly:
@zOnStart()
private async _fetchData() {
const response = await fetch('https://api.example.com/data');
const data = await response.json();
this.zcomponent.nodes.myTextNode.text = data.someField;
This method leverages the browser’s fetch Web API; which you can learn more about here.
Example usage
import { Behavior, zBehavior, zOnStart } from '@zcomponent/core';
import Scene from './Scene.zcomp';
@zBehavior({ icon: 'cloud_download' })
export class FetchDataBehavior extends Behavior<Scene> {
@zOnStart()
// Update a text node with the fetched value
For loading that should block the experience start (e.g. required assets), consider using the @zLoad decorator instead, which integrates with Mattercraft’s progress screen. See Custom Components for details.
